Horrible vibration
Old 07-29-2009, 06:46 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Its most likely hitting the torque box or the upper control arm. I had a similar issue with my catback and it took a few trys adjusting but I finally got it
WhiteFoxGT is offline
Old 07-29-2009, 11:47 PM
gunpig0313
gunpig0313's Avatar
Thats about the spot were mine was rubbing also check up by the mufflers mine was hitting up there too. It was the angle of the mufflers they were pitched up towards the outside of the car.
gunpig0313 is offline
Old 07-30-2009, 01:48 AM
toolegit86
toolegit86's Avatar
does it happen all the time or just under power?? does it go away when you let off the gas?
toolegit86 is offline
Old 07-30-2009, 10:28 AM
Hangwire
Hangwire's Avatar
What about a loose ballast? I've heard the welds giving out on these can cause this....I believe that is my problem. I put on MAC catbacks after being rear-ended and bending my right catback. Ever since then my right side vibrates HORRIBLY between 1900-2300 RPMS but absolutely none outside of that range. I've re-adjusted the right side 3 million times as at first it WAS tapping the gas tank. At this point i'm beginning to think the colission screwed up one of my ballasts.
Hangwire is offline
Old 07-30-2009, 03:38 PM
Adam03GT
Adam03GT's Avatar
Thanks, i will check eath of those spots and i will come back with an update. I will probably have it off the ground in about an hour and i will update.
It ONLY occurs above 45-65 (seems to vary) and ONLY when i let off the throttle. If i hold down the throttle, even slightly, there is no noise.
I just hope i get this annoying problem taken care of..
Adam03GT is offline
Old 08-15-2009, 03:59 AM
medrick
medrick's Avatar
did you get it fixed?
medrick is offline
mtgldr
02-03-2024 09:00 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
GLOCKer
09-28-2015 07:36 AM
mdj89
09-23-2015 08:49 AM
Quick Reply: Horrible vibration
