Clutch Cable Problem
I have a 2001 GT with a 99 cobra motor with a spec stage 2 clutch and aluminum flywheel... now when i first swaped the motor i had the original clutch cable installed but eventually changed it for a steeda because the clutch pedal would get stuck as if the cable was binding so i figured that was the problem..well after the new cable the samething still happend until eventually it got to the point were the cable would get stuck to high and i wasnt able to shift..so as i was driving and got mad since i wasnt able to get it into gear i pressed it really hard and it like popped and i lost all my pedal effort... so i towed it home and checked it and was able to get my pedal feel back and now i am able to shift into 1 thru 5th gear with some effort but cant shift into reverse...now do u think its just the cable or the transmission syncros got jacked up? it has the T45 trans any advise would be appreciated thanks
similar situation with me. blew my first clutch then got a new one ram clutch or something like that...HORRIBLE, tension is way high, went through 2 cluch cables (steeda cables suck, the ford ones are much better)...now I sometimes can't shift into reverse, I have to pump the clutch once or twice and shift into another gear, then it will go into reverse...
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
