Last edit by: IB Advertising
Browse all: Brake Guides
- Ford Mustang Gt 1996 to 2004: How to Replace Brake Pads/Calipers/Rotors
Step by step instructions for do-it-yourself repairs
Changing brake pads for the first time.
I've made up my mind to try and change my front brake pads myself to save me some cash. I've never changed brake pads before but I looked up a bunch of how to videos on youtube. It "seems" simple enough. My question is, is there some little trick or some helpful hints I need to know. I know I need a tool to compress the caliper piston. Is there anything else? thanks guys, and wish me luck.
Do the one on the passanger side first. You can use a c-clamp. I just use a big old screw driver. You have to take the pads off and then put the caliper back on. Use the screw driver between the rotor and the caliper piston. Then pry back on the s-driver. Till the piston is all the back in. Then just take the caliper back off and put the the pads in and reinstall the brake caliper. Do not take any brake line loose. When you are finish with both side all the fiuld should be back in the master cylinder. Hope this help you out.
Take my word for it, Form makes the EASIEST cars to do brakes on. Also we have 4 wheel discs... can't beat that - it's ice cream.
^+1 on channel lock pliers to compress the pistons before putting them over the rotor and pads..
+1 on the grease. I didn't do it on my rear brakes and 8 months later they froze and I had to replace the bracket. I was lucky that my local Autozone said the new pads and rotors were covered under the warranty.
