What the heck kind of alarm system do I have?
Old 07-31-2009, 05:07 PM
Evenexchange
Evenexchange's Avatar
Default What the heck kind of alarm system do I have?
What kind of alarm do stock Mustang GT's have? When I press the button on my fob, the car beeps twice not with the horn, like a electronic beep, and the beeps come from a black speaker thing mounted on the top of the firewall.
Evenexchange is offline
Old 07-31-2009, 07:05 PM
Drew2672
Drew2672's Avatar
Sounds like an aftermarket alarm. The back of the key fob or inside could teel you who makes it. Or you could look under the dash for the module that the speaker is plufgged into to find out more about it.
Drew2672 is offline
Old 08-01-2009, 08:24 AM
Evenexchange
I always just took the alarm for granted. It also has a red light that slowly flashes on the dash near the rear window defogger button on the far left near the steering wheel. Is this light stock?
What do all of your cars do when you press the "lock" and "unlock" button? By the way, this alarm I have works with the stock key fob.
Old 08-01-2009, 11:29 AM
jrherald420
jrherald420's Avatar
my old mustang did nothing when unlocking but if you pressed lock once it just locked, if pressed twice the horn would honk plus the running and fog lights would flash.
jrherald420 is offline
Old 08-02-2009, 01:00 PM
Drew2672
Drew2672's Avatar
No it's not stock with the red led light. Look under the dash around thesteering column area and you will likely find the control modue or the "brain" to see who's alarm it is.
Drew2672 is offline
Old 08-03-2009, 10:24 AM
GrayGT02
GrayGT02's Avatar
Yeah my stock alarm does the same thing as jrherald420's
GrayGT02 is offline
Old 08-03-2009, 11:39 AM
mvr
mvr's Avatar
my car has a aftermarket alarm system in it from before i owned it. its mad annoying and i have no information on it so i just keep it off. there is a kill switch for mine near the hood latch release. mine also has a little red light, if its blinking on or off means different settings for it.
mvr is offline
Old 08-03-2009, 12:49 PM
945LSTANG
945LSTANG's Avatar
+1
sounds like my stocker.
945LSTANG is offline
Old 08-03-2009, 01:21 PM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
Yeah, a red/blue light + electronic horn= aftermarket system. Most popular system is Viper, see them all the time. They have a black 3 button remote, 4 button with trunk option.
ChalknCover is offline
Old 08-08-2009, 09:53 AM
jtfrog
jtfrog's Avatar
Ford had aftermarket alarms installed and then put a ford sticker on the module. I have this on my 01. There is probably a little black button by the driver kick panel. Try this, turn the key to run but do not start, press the red blinking light for 5 seconds then tun the key to off. This should put it in valey mode and now you should only here the car horn.
jtfrog is offline
mrtrodonet
09-19-2020 03:12 PM
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: What the heck kind of alarm system do I have?
