Car Is Throwing Codes
Old 08-07-2009, 09:47 PM
boothay
boothay's Avatar
Default Car Is Throwing Codes
Code P0402 and P0403 Something to the effect of (egr insufficent flow - stuck open at idle) What can I do To fix this guys? Thanks in advance.
boothay is offline
Old 08-08-2009, 08:24 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
P0402 is excessive flow, work the problem list shown here.
Or remove all the clutter, get a block-off plate and cap the tube, then disable EGR in the tune...
cliffyk is offline
Old 08-09-2009, 11:14 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Why delete the EGR when the code is most likely a bad DPFE sensor?
Remove the sensor and tap it on your hand. I bet theres water that comes out. Replace the sensor and clear the code (its the little black rectangle with 2 small vac lines and a electric plug in it)
WhiteFoxGT is offline
Old 08-09-2009, 01:10 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You take me far too seriously...
cliffyk is offline
djbigskrilla
09-20-2022 01:04 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Mnuckolls
08-09-2015 08:54 AM
dragman72
08-09-2015 12:54 AM
Quick Reply: Car Is Throwing Codes
