Trans removal with lts
i got bbk long tubes on nd 3rd gears gone is there a possibility that i can take the trans off the bellhouseing nd pull that out then unbolt the bellhousing nd some how get that out nd this is for my brother with 03 gt
With BBK longtubes I highly recommend you take the headers off. We did a clutch in my friends car and we tried to pull the tranny out without taking the longtubes off. FAIL. We ended up taking it off and it made a job so much easier.
I believe you only need to take out one side for trans removal. Passenger side is it?
My bad I'm used to the T-5 thanks for correcting me on that one. I completely forgot about that with 3650, but correct me if I'm wrong again, but doesn't the 01 Cobra have a T-45 which bolts up like the T-5.
The T45 bellhousing is not reomvable from the outside. Like the 3650, the T45 bellhousing is also the front cover. You cant just pop it off like the T5
I also tried to be sneaky and remove my trans with my long tubes still on.... After a quick ride on the failboat, I just removed them and went on my way.
Personally when I need to remove either the engine or the transmission, I will just take both out because it's a lot easier to do that, especially with a stock K member.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
