Wouldn't a 4prong spark plug be better than 2
Still prepping to get everything put in for the procharger install and was getting new spart plugs, and on lethal performace i'm seeing that they don't offer 4 prong spark plugs. the best they have is 2. Wouldn't 4 be better to ensure that spark is pointed directly to the cylinder? or am i wrong on that?
Yeah - after trying everything - the NGK TR6 or TR55 - depending on the heat range you need (base off your boost level) I'd go with the TR55 unless your above 10-12 psi. Or whatever Motorcraft plugs are stock for your engine.
They actually do work - and dyno - the best over any other plugs.
well i got this because back in the day, the old schoolers would mark their spark plugs to rotate them so they directly fire into the cylinder, thus why they made the 4 prongs.. you say it would make any difference it the spark plug was fireing away from the cylinder?
