Pilot Bearing going bad?
Well Ford's warranty time is 2.3hrs for R+I trans, and .3hrs for clutch replacement. So customer pay your looking at ~5-6hrs labor. Standard Ford shop rate is about 95-97$ an hour. I cant tell you what an independent shop will charge, but it will be close. So figure 500$ in labor plus parts..
I began to second guess myself upon reading the chirping mentioned, but didn't see that post untill after my own. When my bearings were going out, it was a sort of grinding sound and was ultimately diagnosed by my tuner on the dyno. He was able to hear it from under the car under heavy load. I decided to make lemonaid and install a T-56 #1260, as I always hated the HUGE gap between 4th~5th gears and low 1st gear. I have a sticky in this section.
Jazzer
Ok well thanks for all the replies. I'm pretty sure this has nothing to do with the issue but for some reason for the first time ever today when I got into my car the needle just stayed buried at 0. When I started to drive it never moved, finally after about 5 minutes it started jumping around. Than I stopped and it literally jumped up too 100mph while I was in neutral!! The car seamed to idle a lil strange but not too out of the normal, anyone have a quick suggestion on what in the world is probably happening now? guhh
It's still doing it today, it seams strange cuz I have no other electrical problems with the car and none of the other guages move, and it happened right around same time as this t/o bearing deal escalated it seams. These are linked in any ways or the tranny possibly?
The chirping sounds like TOB as stated above since it goes away when you push in the clutch. I have the same problem with my aftermarket one FTL. The speedo being funky and bouncing around looks like a speed sensor issue or maybe the connector/wiring to it.
Ya thats exactly what mine sounds like real chirping like noise seams like its just got progressively louder its so annoying, I don't even have to barely touch the clutch and it will go silent. Like sometimes when I'm at a drive thru or something I'm embarrassed by it and touch the clutch a lil to silence the damned thing!
You're clutch will go out soon. On easter I was cruzzin, heard the noise and smoke came out behind the motor by the transmission and I was like wtf! My clutch went out, literally out of the blue. I heard the noise for a while as well but didn't know what it was and all of a sudden my clutch gave out. Took her home going from 1st-3rd-5th gear..lol
I suggest you don't run your card hard whatsoever. If your on a tight budget ...
