Exhuast Clatter? Annoying Noise
A couple days ago it started off as a little rattling coming from the exhuast i thought nothing of it cause it went away..
Drove it again the next day came back and also went away and then now it is constantly rattling i checked to see if something was loose but it sounds like its coming from the flowmaster muffler
It rattles when cold and warm.. wont go away..this is very annoying and im hoping its the mufflers cause they aint so expensive and i can afford to change em...
If anyone has had a problem like this or similar i would appreciate any help cause its kinda embarresing rolling off and the exhaust is clattering
thanks!!
thanks!!
Do you have an aftermarket mid-pipe? I installed a Bassani o/r x on my 96 and it vibrated on the cross member every once in a while and on every bump. Very annoying. Made me feel like my car was a pos lol. Also felt like it was loose where it bolt up to the header but I checked it and it was fine. I have a similar problem on my Mach now... Its only got weld in flows but at around 2800-3000 it sounds like part of the exhaust is loose, like the flanges on the back of the midpipe are dangling or something? I put it on my uncles lift and everything is tight... I guess I will live with it lol.
