Squeeky noise coming from the AC compressor
Old 08-17-2009, 11:16 AM
Radii
Radii's Avatar
Default Squeeky noise coming from the AC compressor
I've been hearing a squeeky noise coming from my AC compressor, atleast I think it is the compressor on my '00 GT. It's the large metal box looking thing next to the radiator on the passanger side of the engine. Even when the AC is not running, it makes a grinding, groaning kinda noise. Hard to describe but it's a high pitched noise like 2 saw blades rubbing against each other. The AC blows fine and cold. Any clue on what I'm in for?
Radii is offline
Old 08-17-2009, 01:18 PM
cbbass123
cbbass123's Avatar
sounds like your compressor/clutch is about to take the boot. In past vehicles, I usually hear that sort of sound right before the compressor freezes up and dies. Usually happens from lack of oil/age. Look to buying a new compressor soon if the sound is coming from it. Hopefully its not leaving too many shaving deposits in the lines but the orifice tube usually catches em.
cbbass123 is offline
Old 08-17-2009, 01:32 PM
Radii
Radii's Avatar
Anyway to lubricate the compressor or is it a sealed unit?
Radii is offline
Old 08-17-2009, 03:54 PM
hot sauce
hot sauce's Avatar
yea add more of the r134 refrigerant to the compressor or at least check the level because that compressor can lock up anytime and it will either break the belt or lock the motor up and wont let turn over at all happen to me in my 00gt i had to get a a/c delete pully kit to get my car home
hot sauce is offline
Old 08-17-2009, 04:18 PM
LS WHAT
LS WHAT's Avatar
did you run the car without a belt?, it's probably the clutch bearing.
LS WHAT is offline
Tivo304
08-28-2023 12:19 PM
bjdutch2005
03-24-2017 03:38 AM
tmdm
09-04-2015 06:45 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Squeeky noise coming from the AC compressor
