tubular k member, questions reviews
Old 08-28-2009, 12:31 AM
cisurfer
cisurfer's Avatar
Default tubular k member, questions reviews
anyone have them? im thinking about the QA1 but read something about it raising the engine a half inch and the pass side is higher? I plan on staying with stock control arms and springs so just the k member...what are some good ones that arent outrageously priced
cisurfer is offline
Old 08-28-2009, 05:45 AM
uberstang1
Chupacabra
uberstang1's Avatar
I plan on getting the Qa1 aswell, where did you rear about it raising the engine?
uberstang1 is offline
Old 08-28-2009, 08:01 AM
4.698GT
4.698GT's Avatar
Pa Racing K member here. Fits great. Only problem i had was using the stock springs with there spring perch control arms caused the car to sit alot higher. Eventually settled on coilovers to fix that. I will definitely recommand getting the tubular control arms and just going coilover and being done with it. Mustangman281 had a qa1 with their control arms and coilover kit and said he never had any problems with it also.
4.698GT is offline
Old 08-28-2009, 08:21 AM
devongarver
devongarver's Avatar
This may be true...but he also ran 9s at 128 mph....
Regardless, I have heard some claim poor quality on the QA1, I intend to get the UPR setup...Im not sure about PA Racing though.
devongarver is offline
Old 08-28-2009, 10:19 AM
amoosenamedhank
amoosenamedhank's Avatar
I have the QA1 K member and Control arms. The over fit was ok... but for some reason I'm still having alignment issues on the horizontal axis. People say you need to adjust it... but I just don't see the adjustment. Other than that... for the money(cheap), it was ok.
amoosenamedhank is offline
Old 08-28-2009, 11:16 AM
zero2005
zero2005's Avatar
i have a full front QA1 setup. the k-member i got had some problems, but i think it was the fact that the UPR solid motor mounts i got were trash. so i just chucked em and went with my stockers (bleh) prolly switch them out later...
is there a reason you want to swap the k-member? its not exactly the most fun of tasks. also, if you get the k, you might as well get a-arms. or else you'll have to grind the stock arms.
are you going coilover or keeping stock spring location? for some reason my coilover springs hit the outside of the strut tower with -1.0 camber. im thinkin i might have to grind the tower slightly to fit it. not sure what else to do, tried more camber and less but it doesnt help, unless im riding at stock height, but whats the point in that?
zero2005 is offline
Old 08-28-2009, 02:43 PM
Eduardo
Eduardo's Avatar
i wouldnt go with qa1, i have a friend who got just the k-member and it seperated at the welds in 2 locations. he barely races it or goes crazy on bumps(lowered about 2.25-2.5in). when i saw the cracks i was just shocked and when he called qa1 they told him that since it was over a year, he was SOL. ended up taking it to an exhaust shop to have it tig welded. something to think about.
Eduardo is offline
Old 08-28-2009, 02:51 PM
lizzyfan
Underboss
lizzyfan's Avatar
PA Racing!
THE BEST!!!!!
lizzyfan is offline
Old 08-30-2009, 07:51 PM
ESABATM
ESABATM's Avatar
Team Z
ESABATM is offline
FivePointToTheOh
03-09-2020 10:26 PM
aznpersuasion
07-11-2018 06:40 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
Quick Reply: tubular k member, questions reviews
