supercharger question may fit here too
7-10 off sounds like mine.... prior owners might have put 3.73s in then Im sure bald tires probably dosent help though
At part throttle and idle my air/fuel ratios are the same as they were before I had a blower on. With that said if you stay in part throttle and idle your MPG is going to also be the same as stock (or better if your tune leans out part throttle and idle AFR) with a decent tune.
well i have a procharger on my mustang and it gets pretty good mpg i can go from Atlanta,ga to Chattanooga,Tn which is about an 2 hour drive and use just just a little more then 1/4 of a tank and it about 120 mile drive but if you like getting on it you will be making a lot of pit stops at the gas station
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-03-2015 07:14 PM
