Coilover help...
Coilover help...
well, installed Qa1 K member, MMR A Arms and MMr Coilovers tonight, Everything went GREAT!! Until We mounted the tires and the rim is rubbing the Coilover...... Its late.. giving up on it tonight. I have a 17x9 03 cobra wheel with 275's on the front. tire isnt rubbing its the Rim itself..
Do I just need wheel spacers? If sooo how much do i need to go, The Wheel is BARLEY rubbing I dont want a mexican car with the wheels stick far out..
Definitely never heard of anyone running into this problem..
Thanks
Ryan...
PS Looks pretty bad *** if it were drivable lol....
Thanks
Ryan...
O well. I have all the pics on my computer, Once the spacers are in and Everything is working good i will make a new thread with the install pics...
Does the wheel rub once the car is back on the ground?
I can see it rubbing, or being very close, while it is still up in the air, but should be farther away once on the ground. I would be a bit weary of installing any kind of spacer due to a 275 tire. I would expect some rubbing so will very likely need to roll your fenders for clearance.
Jazzer
Jazzer
Here are the pics.
Yes Jazzer. We Put the car down I was going to get on the Drive on lift to tighten everything then get the Alignment. it was definitely rubbing... The First pic if of the side that was rubbing, i didnt hear it rub on the driverside.
What is all involved with rolling the fenders? I know they do it to Drag cars to fit the bigger tires in.. (a quick google can answer my question lol)
yea i didnt read you are running a 275 tire. I am only running a 245 tire. thats about how close mine was. mine only rubbed when i turned the wheel about a 1 turn or 1 1/2 turn each way.
That is a VERY small amount, looks to me. Have you looked into possibly "shifting" the strut away a bit? You could get creative and oval the holes a bit and push it away from the wheel to gain clearance. Wouldn't be difficult, but would have to remove the strut(s) again.
Rolling the fenders involves bending the inside edge away from the tire so you don't rub. There is a "tab" in the front side (9:00 & 3:00 positions) that will probably be the worst offender. DRIVE SLOW untill you confirm you don't rub as the wheels are probably a bit farther outward with the new "K".
Jazzer
EDIT: Maybe you could lower the car a bit more so the wheel bead is "inbetween" the coils
Jazzer
Jazzer
Jazzer
Trying to get everything situated, We wont start working on the car until 7 when friends shop is closed. And the speed shop closes at 5.. Autozone/Advanced doesnt carry much instock.
Either way im sure by tonight i will be good and driving my car again... I wonder how low i can go with the coils...... My X already used to DRAG on Speed bumps.. Now i am going to have to completely avoid speedbumps/ big dips into businesses...
I cant wait to drive it. The Ball Joins on the Stock A arms were just LIMP.. flopping everywhere!! Same with the Rack and Pinion, Just Flopping around. There is soooooooooooooooooooooooooooooooooooo much more room with a Tubular K!!!
You will enjoy the new found ride. I think the coilovers actually ride better comfort wise then the original coil spring set up. That 5/16 spacer should give you adequate clearance. also make sure you can go lock to lock without hitting the springs or anything like that.
you should not need longer studs on your also.
which struts are those?
What's teh offset on your rims? if the rim is rubbing a spacer is the most cost effective solution. The best one is to get replacement rims with a different offest.
I've never been a fan of spacers as they stress the axle and bearing more since the load is pushed further from the fulcrum and acts as a lever.
