Strange vibration just started happening.
Something odd just happened with my car. I was driving it the other day and I noticed some noise coming from the trunk region. Sounded like plastic rattling around, but it only happened around 3000RPM. I looked in the trunk, but couldn't find anything, so I put it out of my mind.
Now I am getting a ton of vibration in the car. Doesn't matter if it's moving or sitting still, in neutral, or in gear. At idle is where it shakes the most. When the A/C is on, it shakes 5 times worse. The most vibration is in the seats, but even the outside mirrors vibrate. Also, it sounds like the exhaust is louder, but I can't find a leak anywhere. On top of that, the plastic rattling is getting worse. It's especially bad if I lay the back seats down.
The engine is staying where it should, not rocking around, so I don't suspect the motor mounts, plus I can hold my hand on the intake and not feel the vibration. The shifter isn't transfering any vibration either, so I am a bit stumped. Any ideas?
Hmm, I figured so. The motor mounts I bought never fit right, so I only got 2 bolts in each one, I am wondering if I bent one. Looking at the engine, it does look like it's bent forward some.
