Symptoms of a Bad Clutch?
2010 Blue Ball Award Recipient
Are there any signs that would lead me to believe my clutch could be going out?
It's a '99 with 86K miles.
Is there a smell? A difference in the stiffness? Does the engagement point change?
If theres a smell of your clutch burning thats usually you not knowing how to drive it i.e riding the clutch way to much, and that would cause your clutch to go bad quicker.
The clutch will start slipping, you may find you have to push the clutch solid to the floor to get it to go in a gear(could just need adjusted) and that the gear won't actually catch untill the clutch is pretty far off the floor, further than it used to.
Burning clutch has a certain strong smell to it that you wouldn't miss if it was slipping. If it was slipping you would know it. Just run it until the clutch is toast IMO. The stock clutch is a lot stronger than you think.
junior04
09-28-2015 10:53 AM
