Injector question?
Old 09-23-2009, 01:20 PM
lawdog205
lawdog205's Avatar
Default Injector question?
How much RWH will 42 lb injectors support reliably..
Thanks
lawdog205 is offline
Old 09-23-2009, 01:27 PM
lizzyfan
Underboss
lizzyfan's Avatar
Thanks
With the right fuel system setup 500rwhp
lizzyfan is offline
Old 09-23-2009, 01:31 PM
mrtstang
mrtstang's Avatar
Around 450 rwhp with a poweradder, and around 500 n/a.
mrtstang is offline
Old 09-23-2009, 01:41 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Ah 500 N/A
WannaBeGearHead is offline
Old 09-23-2009, 02:04 PM
lizzyfan
Underboss
lizzyfan's Avatar
Originally Posted by WannaBeGearHead
Ah 500 N/A
Wrong and wrong!
500 rwhp with power adder and close to 600 N/A
lizzyfan is offline
Old 09-23-2009, 02:19 PM
lawdog205
lawdog205's Avatar
I have a supercharger..and 42 lb injectors..Procharger 10 PSI
255 in tank pump what do I need to get 600 ponies out back?
I have other engine mods as well..
Thanks
Old 09-23-2009, 02:24 PM
lizzyfan
Underboss
lizzyfan's Avatar
Thanks
600rwhp??
Your gonna have to get at least 60lb injectors and upgrade your fuel system (lines, tank, pump)
What year?
lizzyfan is offline
Old 09-23-2009, 03:32 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
If they can really deliver 42 lb/h then its 42lb/h * 8 / 0.5 = 672HP n/a at 100% duty cycle, 538HP at 80% dc.
Running f/i its 42lb/h * 8 / 0.6 = 560HP n/a at 100% duty cycle, 448HP at 80% dc.
These are of course rule-of-thumb numbers--YHPMV...
cliffyk is offline
Old 09-23-2009, 06:04 PM
lawdog205
lawdog205's Avatar
99 model GT..
Has a SHM 5.0 with Forged Cobra crank, forged pistons..9.5 compression, forged connecting rods. Stage 2 port and polish on a set of PI heads. Stage 2 billet blower cams. billet oil pump gears...stock plastic intake stock TB and plenum. 42lb Bosch injectors..stock fuel rails and line. 255lph in tank pump.
Procharger P1SC 10 psi of boost. and some damn ****ty MAF gonna change it ASAP.
Ford motorsport shorty headers Bassani catted X pipe..no other exhaust yet..
Here is what I was thinking..LMK if I am barking up the wrong tree.
DBX97 MAF from Anderson..60lb minimum injectors, billet fuel rails( what size ), pully the Procharger for 15-16lb of boost( what size pully ). I am thinking I will need a better intake system than the stock PI plastic....thinking of a Bullitt or Trick flow..and a twin 65mm TB..
Fuel system completely evades me though..
point me in the right direction here guys..
Thanks
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
treesloth
09-28-2015 07:03 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Injector question?
