Supercharger safe to drive?
I'm thinking about adding a supercharger later on and my tuner is 30 mins away and i was wondering is it safe to drive down there or whats the best way to do it? keep it uder a certain rpm and mph? and its mostly all highway driving.
what s/c are you wanting to add to your car?
If you are going to run just a small amount of boost 6-8PSI, then i say you "can".. Just DO NOT enter boost on a untuned motor. Take it slow and steady and you should be fine. I would however def have a A/F gauge hooked up so you can see how the car is running while driving there.
Me personally, i would just go rent a car dolly or something of that nature and just pull the car to your tuner.
But i would rather be safe than sorry....
I recommend you go to U-haul and rent a $40 dolley. After you change your injectors and MAF it is unlikely that your car will run good enough to drive it to the tuners. If you decide to change your injectors and put on a MAFia at the tuner's shop then it is probably possible if you are getting a centrifical supercharger. A centrifical supercharger doesn't generate a lot of boost at low rpm so keep the rpm below 2000. I personally wouldn't chance it but I've read post from people who have done it.
