helix throttle body spacer
Old 10-08-2009, 01:54 PM
alexh123animals
alexh123animals's Avatar
Default helix throttle body spacer
i have a 2001 mustang gt automatic i just put a helix power tower throttle body spcer and when i go or rev it i cant hear the whistle sound im running an o/r h pipe and flowmaster is it because i have loud exaust or what could it be?
alexh123animals is offline
Old 10-08-2009, 02:00 PM
SVTeeshirt
SVTeeshirt's Avatar
you bought a what? lol you could have just given me the money i woulda spent it on something useful like food. Why would you assume a throttlebody spacer is supposed to make your car whistle? Some Cold air intakes make it whistle.... so do blowers.
SVTeeshirt is offline
Old 10-08-2009, 03:39 PM
ddmsgtr1
ddmsgtr1's Avatar
I'm gonna guess you just got the car, right? Don't feel bad, I bought one of those things too, before I knew any better. If there are two other things I can warn you about, I'd say U/D pulleys and CAI's are almost as much of a waste of money as far as I'm concerned. If you haven't already done those, then leave in the factory pulleys, and take the silencer out of the intake a throw a K&N drop-in filter in the factory box and call it a day.
ddmsgtr1 is offline
Old 10-08-2009, 04:15 PM
medrick
medrick's Avatar
pulled this from their site:
Helix Power Tower Plus
delivers:
Up to 22 hp gains*
Up to 4 miles per gallon gains*
Up to 25 ft lb gain in Torque*
Easy installation
Quiet Operation
Performance benefits across entire power band*
Environmentally friendly with cleaner fuel burn
Fifty States Legal (C.A.R.B # D516-2)
*Performance level may vary among applications and driving style
medrick is offline
Old 10-08-2009, 05:34 PM
SVTeeshirt
SVTeeshirt's Avatar
i like the UP to gains, inother words if your cars making 900whp it will give you 22hp and 25 ft-lbs tq if you're running 20+ lbs of boost.
Old 10-08-2009, 06:15 PM
lizzyfan
Underboss
lizzyfan's Avatar
Thing about T/B spacers are they only fit stock units not aftermarket larger T/B and plenums so really is a waste
lizzyfan is offline
Old 10-10-2009, 07:07 PM
smashten
smashten's Avatar
UD pulleys a waste. I hope not or they got me. From what I remember about power class anything that reduces the load = more power. slower accesory speed requires less power.
smashten is offline
Old 10-10-2009, 08:59 PM
ddmsgtr1
ddmsgtr1's Avatar
That's true but consider two things. One, I can tell you the gain is minimal, and for the price, if you want to reduce parasitic loss you're better off spending just a tad more and getting an electric water pump. Second, should you decide you want to do a blower in the future, you'll be switching back to your stock pulleys anyway. You won't be spinning the blower enough and I've heard that alot of centri's may not fit with the larger water pump and alt. pulleys in place.
ddmsgtr1 is offline
Old 10-10-2009, 09:18 PM
Bullitt2theHead
Bullitt2theHead's Avatar
This may just be me, but buying underdrive pulleys, which can give you insignificant amounts of hp, arent worth it. Simply put, do you really want to slow down your alternator and your water pump on a daily driven/street driven car?
Throttle body spacer on an efi car is an absolute waste. On a carb'd car, yeah its there to give you more intake volume, however an efi intake works on much different principles, so adding that 3 or 4 cubic inches to your intake before the runners does nothing. And any kind of "spiral" that spacer may or may not produce will be negated when the intake runners divvy up the air flow.
Bullitt2theHead is offline
Old 10-10-2009, 11:43 PM
pcs
pcs's Avatar
true, but the stock design is already efficient enough than you will not get much gain, also when you slow down the speed of an alternator, depending on the condition of it, you might have charging issues with it. i got 1 whp change on my 99gt. i bough ud pulleys back in 03, when their werent to many bolt on mods for mod engines. so i dont recommend the UDP for anyone.
pcs is offline
Quick Reply: helix throttle body spacer
