1998 cobra wont start??? need help
i have a 1998 cobra and it wont start i was told it could be the CCRM went out and bought it now that dont work either i can turn the fuel pump on with a hot wire but it dont turn on with the key the car ran fine i parked it and this happens
Have you checked the fuel pump fuse? Also I would check to see if you are getting 12v to the connector at the pump. If that is all good it may be the PATS as well as I believe that turns off the pump.
When you jumper the pump will the car start?
11-10-2015 11:39 AM
09-08-2015 06:25 PM
