how to prime an oil pump
Old 10-14-2009, 11:40 AM
stalkr
stalkr's Avatar
Default how to prime an oil pump
how do you prime the oil pump of a 4.6 2v
stalkr is offline
Old 10-14-2009, 09:00 PM
Bullitt2theHead
Bullitt2theHead's Avatar
It is possible, but its a pain in the ***. The best way to do it involves an external pump with some plumbing.
The easiest way-Pull your fuel pump relay, crank 10 seconds. Give the starter a bit to cool down, repeat a few times.
Its not the best method but it works. Better than starting it dry.
Bullitt2theHead is offline
Old 10-15-2009, 12:58 PM
ShadowDrake
ShadowDrake's Avatar
Hold the throttle at wide open, and the ECU will disable spark and fuel and will just crank. Ford added this intentionally. No, I'm not kidding.
A note of warning, it only does it for the FIRST crank after the key has been turned on. If you decide that wasn't enough priming and try the starter again while still holding WOT it -WILL- start. Just turn the key to off, then back to on, hold wide open again, and crank.
Better method even than pulling the fuel pump relay.
ShadowDrake is offline
Old 10-15-2009, 05:02 PM
Frostbitten
Frostbitten's Avatar
i believe the best way is to attatch a line to the block and use a hand pump. But from what I hear these cars dont need a whole lot of priming for the initial start up. You can just pull the injectors and ignition wires. Thats how I did mine and somehow magically the engine started turning over slowly on its own. Was basically turning with no fuel or spark. Dont know how it happened
Frostbitten is offline
Old 10-17-2009, 12:36 AM
stalkr
stalkr's Avatar
i was told to unplug the crank sensor and crank the engine. to do it for a few times, plug the sensor back, and turn it on. have you all heard about this method before.
stalkr is offline
Old 10-17-2009, 01:47 AM
Frostbitten
yes but even with that method it still takes a second before the pressure builds up. If you used proper assembly lube it should be fine, but its always nice to know it has oil pressure during the first strokes of turning over the motor. The less bearing material you lose during startup the better and more bearing material means longer lasting and more durable it will be
Old 10-17-2009, 08:08 AM
Chris98Gt
Chris98Gt's Avatar
If you've assembled the motor correctly with lube and filled the oil pump with lube like the book says then there is plenty of assembly lube on everything for the initial start up before the pump makes pressure.
Chris98Gt is offline
Old 10-17-2009, 09:54 PM
stalkr
stalkr's Avatar
wat do you mean with fill up the oil pump? i havent done any fill up! how do i do the fill up
stalkr is offline
Old 10-17-2009, 11:12 PM
Sxynerd
Sxynerd's Avatar
Don't worry about it, just start the car.
Sxynerd is offline
Old 10-18-2009, 08:41 AM
Chris98Gt
Chris98Gt's Avatar
Before I put the pickup tube on the pump I filled it up.
Quick Reply: how to prime an oil pump
