Whining from timing?
Old 10-20-2009, 11:26 PM
Stone629
Stone629's Avatar
Check your alternator. The sound it makes when the bearings are going out sounds just like a power steering pump running low fluid.
Stone629 is offline
Old 10-21-2009, 10:23 AM
neilca
neilca's Avatar
I have a 1998 GT and am experiancing the same thing after replacing my serpentine belt because the old one was frayed. The original belt did not make noise.
I replaced both pulleys and the water pump with no change in the noise. I spent many hours reviewing postings on this sight and on others for the same problem. No one would definitively say what caused or fixed the noise.
I believe it is caused by misalignment of the pulleys or the amount of bending (backwards the belt has to do over the water pump). The noise was bad on my car yesterday, I went home and sprayed silicone spray on the flat side of the belt only. The noise immediatly stopped and would not return even when revved.
My path forward is to
1. Continue to drive until the belt "breaks in" or
2. Replace the belt with the Goodyear Gaterback. The reason I think this would work is because the Gates belt I bought at NAPA has continuous ribs on the inside of the belt. The Goodyear belt breaks up the ribs so it is easier to bend the belt backwards.
Has anyone fixed this problem by using the Goodyear belt?
neilca is offline
Old 10-26-2009, 08:48 AM
neilca
neilca's Avatar
I changed my belt this weekend to the Goodyear Gatorback belt. Problem solved. All I hear from the engine is the exhaust note.
neilca is offline
mungodrums
10-07-2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: Whining from timing?
