is it a really bad cranshaft?
Old 10-22-2009, 04:51 PM
mustang90242
mustang90242's Avatar
Default is it a really bad cranshaft?
i took my 1999 cobra to several mechanics to see what was wrong with my car because it was doing a ticking noise after 2300 rpm
and 3 mechanics said my crankshaft needed to be replaced
i dont really trust them....could that ticking noise be because of a bad crankshaft?
mustang90242 is offline
Old 10-22-2009, 05:44 PM
JC316
JC316's Avatar
They probably think that it spun a bearing. If so, then the crankshaft COULD need replacing, or it could just need to be machined.
JC316 is offline
Old 10-22-2009, 09:13 PM
dimebag
dimebag's Avatar
If its a rod bearing toulll get a knock, not a tap.and it'll do it at idle too. I'd pull the valve covers 1st. And if the crank is hurt u can usually go .010 under, get bearings for that app. Unless the stress cracked it then its fubar
dimebag is offline
Old 10-22-2009, 09:39 PM
EagleStroker
EagleStroker's Avatar
What he said.
EagleStroker is offline
Old 10-22-2009, 11:13 PM
mustang90242
do you know an estimate of what i should be expecting for the repair
Old 10-22-2009, 11:15 PM
mustang90242
it sounds normal when its at idle
wat do you mean .10 under?
Old 10-22-2009, 11:18 PM
EagleStroker
If the journal is damaged but not cracked, they will grind the crank. Each step down is in "10s"
Old 10-22-2009, 11:40 PM
mustang90242
do you know how much that will cost by a repair shop?
Old 10-23-2009, 02:32 AM
97modifiedmustangGT
97modifiedmustangGT's Avatar
to get a crank ground it can be anywhere from 50-100 bucks
97modifiedmustangGT is offline
Old 10-23-2009, 11:35 AM
Xemeth
Xemeth's Avatar
True, but judging from the OP's posts, I highly doubt he'll be tearing down the motor himself and then re-assembling everything.
OP, you're looking at a few grand.
Xemeth is offline
Quick Reply: is it a really bad cranshaft?
