Cam degree article
Old 11-01-2009, 08:56 PM
stangalator
stangalator's Avatar
never knew the stock cam gears were plus or minus 4 degrees, i think when i do cams one day I'll get those cams from them that are with a closer tolerance. Good find
stangalator is offline
Old 02-05-2010, 11:51 AM
nickmckinney
nickmckinney's Avatar
Here is a serious news update -
After doing a bunch at one time I have learned the cams have more issues than the gears. I just did a set of cams that were supposed to be 110 and found 102 and 112. The 102 of this monster cam had the valve into the piston even with a piston notch. Even the OEM cams vary a few degrees I have learned.
nickmckinney is offline
Old 02-05-2010, 02:01 PM
lizzyfan
Underboss
lizzyfan's Avatar
Which monster cam????
lizzyfan is offline
Old 02-05-2010, 04:28 PM
nickmckinney
It was an "other brand" cam with over 240 duration at 050.
I have seen it from all of them though.
Old 04-04-2010, 10:57 PM
Pontisteve
Pontisteve's Avatar
Nick, what do you do about getting the dial indicator extension angle correct on a 4V? I find the cam caps are in the way of the ideal angle, and it shows up as inconsistent peak valve lift. I've ended up both short and long in testing.
Also, do you know where I can find factory cam cards? I'd like to know the stock opening/closing specs (plus all other specs) for 96-98 4V.
Timing a 4V is extremely frustrating. I've been working on it in my spare time for a VERY long time, trying to perfect the process. Built many new tools, bought better versions of all the manufactured tools you need, and still not convinced I have it right. The 18" moroso degree wheel I use is so large, and therefore more accurate, that it'll scare you how much you can be off from test to test. Ever try checking a cam, then tearing down your entire setup, re-setup from scratch, and check it again? It's humbling.
Great tip about the earlier modular valve retainer. I've got to try that. The angles on my 97 drive me nuts in inconsistency. I was just thinking today that the hot setup might be a custom made "retainer" that acts as an extension plate. That would cure the stupid cam cap angle problem.
Pontisteve is offline
Old 04-05-2010, 07:47 AM
nickmckinney
Best way is to remove the head and zero the piston directly. Its a biach doing it through the spark plug hole on any head. If you zero number 1 on the pass side it should also be perfect for number 6 on the drivers side so you don't have to move the wheel side to side.
Old 04-06-2010, 02:58 AM
Pontisteve
Pontisteve's Avatar
I have a long piston stop from Innovative Products of America. It's just barely long enough to reach all the way up the plug hole without needing any tools to get to it. On the 4V, with the plug pretty much in the middle of the piston, I think that's not too big of an issue.
Any thoughts about the other stuff I mentioned?
patchshaffer
Tuner Central
10-05-2015 02:24 PM
10-05-2015 07:40 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
10-01-2015 05:13 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Cam degree article
