Emissions are killing me. O2 sensor help
Old 10-29-2009, 09:46 AM
jim135666
jim135666's Avatar
Default Emissions are killing me. O2 sensor help
alright to make it short and sweet i have xpipe wit a straight pipe flowmaster 40, NO CATs, and now my inspections over due. I usually get hookedup but now i dont so i need to find a way or i have to pay 800$ to make it legit.
MIL Eliminators, they plug into xpipe and h pipes. Too my knowledge i have 4 sensors i believe, 2 in front and 2 in the back. Would these parts be able to trick the inspection computer. If it turns my light off and blocks the 02 code it should block there codes as well. If it does work, how many will i need? thanks
jim135666 is offline
Old 10-29-2009, 09:59 AM
jim135666
jim135666's Avatar
in addition, it says they plug into the xpipe and looking at my stock exhaust theres 4. So im not sure if this would work.
Old 10-29-2009, 12:05 PM
smitty2919
smitty2919's Avatar
im assuming you have a 96 or newer car if ur worried about emissions (in MA anything 95 and older doesnt get emissions tested) but for my 04 GT (actually anything 96 and newer with OBDII) the guy doesnt even run the car. he just plugs the computer into the OBD port and if the car has any stored codes then it fails. if not then you pass.
a while ago he used to run the car on drums with sniffers in the tailpipes.
conclusion:
if you dont get sniffed nor a visual inspection(if you dont have cats you SHOULD fail right off the bat) then make sure the car doesnt have any codes. in other words yes do MIL so it doesnt throw codes. i THINK (dont quote me on it) that you only need 2 MIL's because what throws the codes are the 2 O2's after the cats.
when the difference in readings of the front and rear O2's are not within spec of the computer the CEL will come on. if you turn the rears off then the car thinks the cats are there and working fine.
smitty2919 is offline
Old 10-29-2009, 10:22 PM
jim135666
jim135666's Avatar
so you think this eliminator may help my case out. so far i gotta drop in the MIL then clear the codes and go 100miles
Old 10-30-2009, 12:53 AM
rafacalz
rafacalz's Avatar
or you can get a tuner, and turn them off, and yes all you need are the rear mil. don't know about going a 100 miles thing. before you do the install disconnect the battery then reconnect after your finish, the the codes should clear out.
rafacalz is offline
Old 10-30-2009, 07:11 AM
smitty2919
smitty2919's Avatar
or you could risk it...after you put them in, since it taked a day or 2 for a code to pop up, go right to the test before it has time to throw a code.
Old 10-31-2009, 12:28 AM
Lowtryx
Lowtryx's Avatar
There is no question, if you're levels are being tested and you have no Cats, you're not going to pass. Plain and simple. The last Stang I E-Tested without cats was spitting out 10,000 Parts per million Hydrocarbons. The limit was under 100.
Lowtryx is offline
djbigskrilla
09-20-2022 01:04 AM
mrtrodonet
09-19-2020 03:12 PM
mltdwn12
09-23-2015 08:54 AM
guarnibl
08-10-2005 04:06 PM
sq2drsq
05-28-2005 03:22 PM
Quick Reply: Emissions are killing me. O2 sensor help
