Engine RPMs
Engine RPMs
rev up fast - very good engine design</P>
rev down slow - rotating inertia. once the assembly gets spinning there's alot of kinetic energy, the only thing causing it to slow back down are frictional & windagelosses. put it in gear and let out the clutch, that will make it slow down faster. </P>
Engine RPMs
i do that some times but id just like to not have to do that every time i want the rpms to go back down besides its not too healthy for the clutch.</P>
Wouldnt an aluminum flywheel help this???</P>
Engine RPMs
yes, but i don't know how much.</P>
as far as hurting your clutch, thats not going to happen by just revving your motor in neutral and using the clutch to slow it down. it undergoes a lot more stress even when you accelerate lightly. that is if you're not dropping the clutch, just ease it out to slow it down faster.</P>
musnicki
09-23-2015 07:11 AM
zanemoseley
09-06-2015 12:58 PM
