Help Won't Start
Help Won't Start
Hey All,
I took off down the road in my 2000 Mustang GT today and the engine started cutting out. When I gave it more gas it would bog until I would let off and it would idle. I got it back home now it won't start at all. I replaced the fuel filter and I have no fuel to the fuel rails. Has anyone had this same problem...????
keep your door open and lean outside hte car and turn the key to accessory. you should hear the fuel pump priming (whirring noise for a few seconds).
look in your trunk and check your fuel pump cutoff. theres a little button inside the trunk on the left side if my memory serves correctly. its designed to cut fuel when you get into an accident or something but occasionally they will pop randomly or if you hit a hard bump.
also...did you install the filter before or after it started acting up? and if you did it before recheck everything you did.
