Old 11-04-2015, 12:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Lowering your 94-04 4.6 GT/Mach 1/Cobra
Old 11-26-2007, 08:02 AM
  #131
Ahnial8u
Ahnial8u's Avatar
Default RE: TECH: Lowering your 94-04 4.6 GT
Lets see some more....
Ahnial8u is offline
Old 11-29-2007, 02:54 PM
  #132
EODMustang
EODMustang's Avatar
The only special tool you need to do the install is a spring compressor. The rest of the install can be done with basic hand or power tools. You can take the springs off without the compressor, but it is extremely dangerous. That spring has enough pressure built up in it to kill or seriously injure you from blunt trauma alone.
EODMustang is offline
Old 03-16-2008, 03:11 PM
  #133
UmX
UmX's Avatar
well i just did the H&Rs super sports before and after.. Just hoping the settle a lil more.. By changing to a 18 help get rid of some more gap?
Dont laugh at my awsome photoediting lol just reinstalled windows again forgot to install photo shop cs3 lol. But anyways the after is the day of the install. lil green dots are where the top of the tires.. for some who cant see the tire.
Close up of after
UmX is offline
Old 03-16-2008, 03:46 PM
  #134
Jbauer
Jbauer's Avatar
18s will help- 295 35 in the rear would fill that gap.
I got sportlines in my car- and i still have a gap, i really haven't seen a kit that lowers like an import, except those intrax 2.5 kits.
Jbauer is offline
Old 03-16-2008, 04:34 PM
  #135
UmX
UmX's Avatar
i did a search for the imtrax all i find is them for a 05+
UmX is offline
Old 10-23-2008, 12:37 AM
  #136
Hlistr_07RR
I always jizz first
Hlistr_07RR's Avatar
Originally Posted by 04BlueGT
If you drop your ride, you have to do something to correct your steering geometry. If you drop less than 1 inch, you can have an alignment done and you'll be fine. If you go lower than that, you need one (or more) of the following:
a) Caster & camber plates
b) Bumpsteer kit
c) Offset rack bushings
The choice is up to you. You can do all three if you wish. I bought 2 inch drop springs and Ford offset rack bushings. My steering is fine and I didn't need an alignment. If you're big into road racing, then C&C plates are a good move. You can actually do all three for the maximum amount of adjustability. The offsets were not a bad install. I went with the aluminum because they are less prone to spin in the rack. I would avoid poly or rubber offsets.
Didn't read the whole thread, but can you explain? Is it hard to install caster camber plates? offset rack bushings seem to be the cheapest, will that make my front tires stop wearing on the inside because now they look to be bowed out at the bottom.
If you look at the right of this page, it shows related products. I was going to get C&C plates, can I install them myself you think?
http://www.americanmuscle.com/steering-offset.html
Hlistr_07RR is offline
lincolnshibuya
07-05-2020 03:05 AM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
NYstang
09-30-2015 09:56 PM
Quick Reply: Lowering your 94-04 4.6 GT/Mach 1/Cobra
