Basic Mods for your 96-04 GT/Mach 1
#61
RE: Basic Mods for your 96-04 GT/Mach 1
i have a 2003 mustang gt 5 speed i got K&N cold air intake, bassani catted x pipe with magnaflow mangapacks, 3.73 with superchips and i dont know what i could do next can anyone help me out with any suggestions thanks
#62
ORIGINAL: 5GTStang03
Piggyback pulleys come with a new crank pulley, but it has no damper built into it, so you have to take your HUGE STOCK CRANK PULLEY and bolt it to the front of your new underdrive pulley!! Totally ruins the 'less rotational weight' crap March feed's you... You'll still feel the difference with piggybacks, but it won't be as significant as non-piggyback's.
#63
would i have to get a better alternater because i herd that it does not charge as well. o yea but i would get the non pigback
#64
Your stock alternator will be fine and you will have no charging issues.
#65
^^just to add on to what he said. You will not have any charging issues but some power items may work slower. i.e. it's normal for you power windows to raise and lower slower with pullies. Nothing dramatic though.
#67
Just about evey mod for the mustang gives more torque than horsepower.
#68
i think i have done most of the little bolt ons but are cams worth it or would i have to change a bounch of other stuff
#69
hp is good but it just gets u wanting to go faster i think is more fun to be going and punch it and spin the tires or throw ur head back in the seat. but i want to get some more mods but would i have to change heads and intake and all the other stuff if i got new cams
#70
if you get stage 1 cams you can use stock tune and it should idle ok. if you go stage 2 its recommened that you forge your bottom end, 3.55+ gears, a tune, for the full power of stage 2s.
