Replacing the Intake Manifold
Old 01-01-2015, 03:33 PM
mjgalvan24
mjgalvan24's Avatar
I have a 2004 mustang gt and the 1st time I replaced my intake it had 90k now my car has 160k and is leaking again. I’m assuming that they are only good for 90k miles? Do yall recommend the plastic again? I want a part that will last longer
mjgalvan24 is offline
Old 01-01-2015, 03:36 PM
mjgalvan24
mjgalvan24's Avatar
since my car is leaking again at 160k does it mean i have a bad intake and i have to replace it with a new one or is it a gasket issue?
Old 01-01-2015, 05:29 PM
Camster
Camster's Avatar
Probably needs another new intake manifold.
My 04 failed around 60k,two years old.Upfront on the passenger side.
I added some sealer at the back of the block valley,where there is a loosely fitted plastic cap.Should I have another manifold failure,at least I shouldn't have antifreeze rolling back and dripping into the clutch.When that happens,all sorts of shudders when you pull away from a stop.
I considered a metal version,but got the impression that a new throttle body and fuel rails were required.
If I can get eight years out of the replacement,as I did with the original,that's fine with me.Doubtful that I'll be the owner at that point,and if I am,no big deal.Another you change one,the next one goes easy.
I feel that they're good for just so many heating up/cooling off cycles,rather than mileage.
Camster is offline
Old 01-05-2015, 09:57 PM
kast1376
kast1376's Avatar
I replaced mine at 140, and now have a bad (and so far unlocated) vacuum leak that causes knock at wot. If the manifold is cracked again (with less than 5k on it) I'm gonna be pissed, but bite the bullet and buy the aluminum replacement. Just not sure if it will pass ca smog.
kast1376 is offline
Old 01-08-2015, 06:21 AM
dhavi4226
dhavi4226's Avatar
Here's a real good video HOW TO on replacing a PI manifold on a Non-PI engine.
https://www.youtube.com/watch?v=Q3aTGbuCMQg#t=26
And don't forget to look at the sticky at the beginning of this forum.
dhavi4226 is offline
djbigskrilla
09-20-2022 01:04 AM
mirandaandjimmy
11-16-2015 08:51 AM
mtxplod
08-29-2015 01:43 AM
Calizic
08-28-2015 01:46 PM
soulcaliber39
08-26-2015 03:26 PM
Quick Reply: Replacing the Intake Manifold
