Stock fuel injectors? 2002 GT, which ones?
Old 11-25-2009, 02:26 PM
stagnet04
stagnet04's Avatar
Well I put in some redline fuel injector cleaner to see what happens,hopefully Ill have some time next week to change the fuel filter and if that doesnt work then its new injector time....Thanks for the info....
Ill keep this thread updated for others that might have similar problems....
stagnet04 is offline
Old 12-06-2009, 02:51 PM
stagnet04
stagnet04's Avatar
Well finally had a chance to change out the fuel filter and it made an ENORMOUS difference, the hesitation is almost all gone and the power is almost all the way back,BUT it still doesn't feel 100%....
I already ordered a can of BG 44k to see what that will do and if that fixes everything then awesome, if not, on to another step....Ill keep this updated....
Any other suggestions are always welcome....
Old 12-06-2009, 04:07 PM
02BLK GT
02BLK GT's Avatar
Do the easiest things first, check your spark plugs as said, and test your wires, or make sure they are on their right positition.
02BLK GT is offline
Old 12-10-2009, 03:15 PM
stagnet04
stagnet04's Avatar
Well its been 2 days since i putin the BG 44k and it has made a difference in pick-up and overall power with a slight difference in smoother idle, BUT in the lower RPMS in each gear it STILL lundges and kind of hisitates. I checked the wiring and a mechanic checked the fuel pump and he said that looks good, so now Im down to the fuel injectors.
-Does anyone know where I can get a set of stock fuel injectors at a decent price besides the dealer?
-Is there another brand I should look into?
-Also, should I upgrade to a higher lb injector, like lets say a 21lb or 24? I know stock is 19lb....
Thanks....
Old 12-10-2009, 03:20 PM
lizzyfan
Underboss
lizzyfan's Avatar
Get a new mechanic!
lizzyfan is offline
Old 12-10-2009, 03:28 PM
stagnet04
stagnet04's Avatar
Originally Posted by lizzyfan
Get a new mechanic!
Beleive me, iv been to 2 so-called mustang specialty shops around here and theyre both knuckleheads, thats why I try to stick to asking the forums....
Old 12-10-2009, 04:03 PM
Tim99GT
Tim99GT's Avatar
Originally Posted by cliffyk
How many miles on it? What other mods?
Unless you have 150k+ miles, or it's been run on donkey **** for it's whole life, I doubt very much you need injectors...
What octane rating do you think that has.... Might be a cheaper alternative to C-16
Tim99GT is offline
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 08:51 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Stock fuel injectors? 2002 GT, which ones?
