Transmission
Old 12-08-2009, 05:46 PM
Warrior1876
Warrior1876's Avatar
Default Transmission
I have a standard stock transmission in my mustang and want to upgrade the hp to around 650. Will i need a new transmission or just a better clutch. THanks
Warrior1876 is offline
Old 12-08-2009, 05:57 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Both.
You have an 01, so it could either be a t45 or 3650.. I'd need your VIN to tell you which one it has. When your pushin that much power you can get away with stock trans, but the stock clutch wont hold. And also, I've seen stock trannys break with 300 less horsepower than what you want to make.
WhiteFoxGT is offline
Old 12-08-2009, 07:32 PM
Warrior1876
Would you recommed upgrading the trans. I really dont want to spend the money but i hear its only rated at 360 torque. If i am around 600 hp isnt that pushing it. If its going to hold with an upgraded clutch i will stick with it but want to make sure i am ok.
Old 12-09-2009, 08:59 PM
97dustang
97dustang's Avatar
I broke my trans with a stock motor, i had a t45, i went with the tko 500 and absolutely love it, i would recommend the tko600 for you though, if you plan on makin that much power your gonna make alot of torque too, and i would much rather have a trans that is stronger than necessary than have one thats too weak. If you talk to Tom Thompson at AMP Performance 1-800-454-8387 he can hook you up with a great package deal with a centerforce clutch, pressure plate, and the fluid you need too, great guy to deal with and great prices too.
97dustang is offline
Old 12-10-2009, 02:43 PM
amoosenamedhank
amoosenamedhank's Avatar
I would look into a promotion transmission or a T-56, depending on your budget. I have heard nothing but good from both setups.
amoosenamedhank is offline
Old 12-10-2009, 03:31 PM
lizzyfan
Underboss
lizzyfan's Avatar
T-56 is what ya want
lizzyfan is offline
Old 12-10-2009, 03:59 PM
Tim99GT
Tim99GT's Avatar
^^ +1
Tim99GT is offline
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Transmission
