More problems
Old 12-19-2009, 05:36 PM
avlon06
avlon06's Avatar
Default More problems
So I had my battery replaced about 3 weeks ago and left the cables disconnected from the poles while I was away at school. Came back today and connected the wires and no start. Been having this battery problem for quite some time now, replaced multiple batteries as well as 2 alternators... Why do I keep having this problem??
avlon06 is offline
Old 12-20-2009, 12:22 PM
Z28KLR
Z28KLR's Avatar
I've had brand new batteries before that needed a jump to fire up the first time. What's your car doing, just not holding a charge? Might check to see if, when the car and all accessories (incl. alarm) are turned off if there's still any current drawing from your battery. If you don't have a multimeter you can probably get one of the goofballs down at Autozone to check for you. If there is a draw, start pulling fuses, one at a time, until you find which circuit it's coming from.
Z28KLR is offline
Old 12-23-2009, 01:06 PM
devongarver
devongarver's Avatar
Word.
devongarver is offline
Old 12-23-2009, 01:24 PM
Sxynerd
Sxynerd's Avatar
Check your grounding straps and make sure they're not corroded.
I have a GPS tracking system on my car and after just a few days of sitting on a weak battery, it's slow starting.
Use a DMM and check for voltage draw.
Sxynerd is offline
Old 12-23-2009, 03:09 PM
avlon06
avlon06's Avatar
Turns out the battery only had 2?? cold cranking amps, so it wasnt enough to start the car, the guy at napa also suggeted to get a trickle charger and have it connected and running at 2v while im away at school
avlon06 is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: More problems
