Car is ****ed up...
Old 12-22-2009, 09:35 PM
mike08
mike08's Avatar
Exclamation Car is ****ed up...
Couple problems with the mustang
1. on SOME cold start-ups the car will hesitate hard and have a really rough idle. The car idles at right above 500 and the rpm's will lope up and down, eventually the car will die.
2. sometimes the car will miss at idle and then go away leading me to believe that it is not a COP.
3. After hard acceleration, i will put the car in neutral and coast to a stop. most times the car will die afterwards.
Any suggestions for any of the problems listed would be a big help guys. Thanks in advance.
mike08 is offline
Old 12-22-2009, 09:57 PM
vanquish
vanquish's Avatar
IAC valve
vanquish is offline
Old 12-22-2009, 10:10 PM
bopiela
bopiela's Avatar
^ +1 vanquish
bopiela is offline
Old 12-22-2009, 11:19 PM
mike08
mike08's Avatar
alright ill try it out
mike08 is offline
Old 12-22-2009, 11:57 PM
Pubydingus
Pubydingus's Avatar
try replacing your fuel filter?
Pubydingus is offline
Old 12-23-2009, 03:01 AM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
definately IAC
although, fuel filter should be done every 3 oil changes anyways, so it cant hurt to replace that also
99BlackPonyGT is offline
Old 12-23-2009, 10:11 AM
99GTvert
is my username.
99GTvert's Avatar
Your car is sniper tuned...what is the current idle rpm's set at? On my car, it would also die on me sometimes when I'm in neutral, but replacing the IAC helped a little bit, but then my car was dyno tuned and I noticed the idle rpm was raised to about 1k. The car's rpms would still drop sometimes, but it doesn't completely die out on me nearly as much.
99GTvert is offline
Old 12-23-2009, 12:38 PM
devongarver
devongarver's Avatar
Yup I'll hop on the IAC boat too. And definately replace the fuel filter if you havent in the last 10-15kmiles.
devongarver is offline
Old 12-23-2009, 01:04 PM
Frostbitten
Frostbitten's Avatar
ill just say its something with the air intake
Frostbitten is offline
Old 12-23-2009, 01:32 PM
99BlackPonyGT
ill just say its something with the intake of air
Quick Reply: Car is ****ed up...
