lowering springs help?
Old 12-23-2009, 03:40 PM
jared_brown
jared_brown's Avatar
Default lowering springs help?
my H&R Super Sport springs will be here tmrw and i plan to install them as soon as the delivery shows up. 2" front, 1.5" rear..will alignment be required? also will i need c/c plates? i'm building on my most recent buy, bone stock 04 GT 40th Anniversary
jared_brown is offline
Old 12-23-2009, 03:55 PM
Sxynerd
Sxynerd's Avatar
Yes you'll need an alignment buy you will be able to drive it.
IDK if you know so I'll just say it, Don't remove your strut from the strut tower, just remove the large bolts at the top of the spindle and zip tie the caliper off to the side.
Sxynerd is offline
Old 12-23-2009, 04:27 PM
jared_brown
alright thanks, yeah i actually just found the install instructions on americanmuscle..another question though, if an alignment had to wait for about a week, how to i adjust my camber? i'll just be eyeballing it to get as close as possible, but i have no idea where the camber adjust is
Old 12-23-2009, 05:09 PM
Sxynerd
Sxynerd's Avatar
Yes, it can last a week BUT it's going to "track" a lot. Don't eyeball it, just install the springs and don't mess with the alignment just drop it and let the shop do it whenever you get around to it.
Did you get Caster Camber plates as well?
Sxynerd is offline
Old 12-24-2009, 07:23 AM
jared_brown
no i didn't somewhere i saw that they weren't always required..and i went off that instead of my instinct..but before i get the alignment i'm going to order them..does it matter if i go cheap?
Old 12-24-2009, 12:11 PM
Sxynerd
Sxynerd's Avatar
The old adage, "you get what you pay for." applies to this as well. Maximum Motorsports, Steeda, BBK are all around the same price of $200. I think the cheapest you're going to find is around $180 for a quality set.
They are not always required but the SS springs are pushing the envelope with how much they can adjust it. I don't have them on my 96 and it's slammed but it still drives well, whereas my 03 sets just a bit higher and needs them badly. I think a lot of it has to do with the shop doing the alignment.
Sxynerd is offline
Old 12-24-2009, 12:26 PM
boduke0220
boduke0220's Avatar
guy that did my alignment said it was a good thing i had the cc plates cause there was no way he could line it up with the stockers. I have the Supersports
boduke0220 is offline
Old 12-24-2009, 06:24 PM
jared_brown
thanks alot guys, we'll see what happens!
lincolnshibuya
07-05-2020 03:05 AM
CS2007
06-25-2019 09:45 PM
UrS4
10-03-2015 06:23 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: lowering springs help?
