cams
Old 12-28-2009, 10:56 PM
nateCR
nateCR's Avatar
Default cams
has anyone ever dealt with the trick flow cam kits for our 2v? looking at the stange 2..
nateCR is offline
Old 12-28-2009, 11:00 PM
mrtstang
mrtstang's Avatar
Those will not fit the stock PI head just so you know. You'll be much better off with something different.
mrtstang is offline
Old 12-28-2009, 11:11 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
^^^ Why won't they fit?
WannaBeGearHead is offline
Old 12-28-2009, 11:20 PM
mrtstang
mrtstang's Avatar
PVT contact will occur. Specs are to aggressive for the stock pi heads
mrtstang is offline
Old 12-29-2009, 02:00 PM
nateCR
nateCR's Avatar
what has to be done to make them work? most of the aftermarket cams like the cms require ptv clearence checking
nateCR is offline
Old 12-29-2009, 02:31 PM
mrtstang
mrtstang's Avatar
Machine or replace the intake valves and/or notch the pistons is one way. Another is to retard the cams to get more ptv clearence. Only problem is that by retarding the cams you'll loose some good mid range power.
Honestly (if you're staying with the stock heads) you're much better off with different cams. The amount of time, effort, and money that it would take to make these cams work and fit correctly, would not be worth it imo. Now if you plan on going with some different heads...well that's a different story then.
mrtstang is offline
Old 12-29-2009, 06:14 PM
nateCR
nateCR's Avatar
so whats the max lift we can run on a stock set up other then springs
nateCR is offline
Old 12-29-2009, 07:39 PM
nateCR
nateCR's Avatar
has anyone used the stage 2 comp cams? whats the max lift for our stock pi valve springs?
nateCR is offline
Old 12-29-2009, 07:58 PM
mrtstang
mrtstang's Avatar
With stock springs you really don't want to go more than a 550 lift. Even that's pushing it. 550 exhaust/500 intake will work well with stock springs if you don't over rev it.
In fact, even with good springs, there isn't much of a benefit to go over a 550 lift on the stock heads.
mrtstang is offline
Old 12-30-2009, 07:16 PM
NinjaMonky
NinjaMonky's Avatar
naw wht you need is some stg. 1 comp's lmk if interested.
NinjaMonky is offline
Quick Reply: cams
