passenger window not closing correctly
Old 01-01-2010, 08:30 AM
fieryfight
fieryfight's Avatar
Default passenger window not closing correctly
the passenger window does not form a good seal to the door frame when someone gets in my car the window is off the the side of the door frame instead of lining up with it looks like the window is going to far up i cant seem to figure out how to fix it any ideas
fieryfight is offline
Old 01-02-2010, 10:47 AM
Snitz
Snitz's Avatar
sounds like someone may have pushed down on your window without it being completly down, i cant think of anything other than opening taking door panel and everything off to see if the window slipped somewhere off the track, or there is a bend in some of the equipment
Snitz is offline
Old 01-03-2010, 02:08 PM
fieryfight
fieryfight's Avatar
ya that or people open the door by grabbing the window i seem to have fixed it by opening the door up again this time i had a little more time than last time and did a better job at trying to fix it then let it stay in the frame for a day to make sure it sets in and it seems to have worked.
Old 01-04-2010, 08:44 AM
jjandascog
jjandascog's Avatar
This seems to be a common occurrence in 99-04 Mustangs. Your passenger window has come unglued from the rear mount on the regulator. When this happens the window tilts forward and will not seal properly and will be 'rolled up to far'.
Remove your door panel and roll the window up and you will see what is happening. It is not hard to fix, you can just re-glue the window to the channel. In my case I replaced the rivet with a 1/4-20 and added a #10 screw. I made some drawing that might help (the drawing is for the drivers side, so just reverse it)
Attached Thumbnails passenger window not closing correctly-door-glass-problem.jpg   passenger window not closing correctly-door-glass-repair.jpg
jjandascog is offline
Old 07-31-2013, 02:30 PM
fox_body_stang
fox_body_stang's Avatar
I know this is old and probably a long shot, but is there anyway to get a higher quality image. I can't make out any of the words.
fox_body_stang is offline
Old 08-01-2013, 12:58 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Here are the window adjustment procedures from the shop manual...
cliffyk is offline
Old 05-03-2015, 12:01 PM
p3fe
p3fe's Avatar
I can not view your pictures please help
p3fe is offline
Old 05-03-2015, 02:43 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
They load fine for me, what device, o/s and browser are you using?
cliffyk is offline
Old 05-03-2015, 07:29 PM
petrock
petrock's Avatar
And here is a video I made a little while ago on how to adjust your window as well as replace the door hinge pins & bushings (which could cause this issue too).
petrock is offline
mtgldr
02-03-2024 09:00 PM
DreadPirateRoberts
09-26-2015 02:11 PM
zachary1988
09-18-2015 11:17 PM
2k232
09-16-2015 10:28 AM
amandahchase
09-03-2015 10:09 AM
Quick Reply: passenger window not closing correctly
