rear end problem?
Old 01-03-2010, 01:50 PM
shwert
shwert's Avatar
Default rear end problem?
when i turn my rear end squeaks, but its not like a metal on metal squeak, its more like a whining, could this be the LSD? and also when i make a sharp left there is a big rattling from under the rear, like the driveshaft is banging on something. i can't find the problem or anything leading to it. it may be that the exhaust is hitting the driveshaft or something but i cant find the problem. and help?
shwert is offline
Old 01-03-2010, 03:21 PM
kugzgt
kugzgt's Avatar
tranny mounts?
kugzgt is offline
cliffyk
TECH SAVANT
cliffyk's Avatar
It sounds like the LSD clutch packs binding...
Have you changed the gear oil or had any work done to the rear axle in the past?
cliffyk is offline
Old 01-03-2010, 03:51 PM
shwert
shwert's Avatar
Originally Posted by kugzgt
tranny mounts?
good idea, that may be it for the noise when i turn, but it isn't consistent. and the previous owner had the rear end oil changed at a votech before he sold it to me and they over filled it. so oil was coming out the overflow tube on the axel but i'm thinking they didn't seal it well enough and now it may be dry. i'm in my garage now about to check it out
shwert is offline
Old 01-03-2010, 07:25 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It may also be that they did not add any friction modifier. Many/most synthetic gear oils don't need it but all dino oils do--without f/m the clutch packs will bind/pop/click etc.
cliffyk is offline
Old 01-03-2010, 07:38 PM
shwert
shwert's Avatar
i think your very right cliffy, i just changed it with some full synthetic and all the noises went away. everyday when i would make the slow sharp turn into my driveway it would make all sorts of noises, which now i recognize may have been the clutch packs messing with the driveline, because it sounded like the driveshaft was gaining and losing the small about of slack that was in it (if that makes sense). but after a lot of circles in my neighborhood the noises were gone. thanks guys
shwert is offline
Tyoung68
08-25-2015 04:31 AM
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
Quick Reply: rear end problem?
