PI intake installed....car runs like $hit.
Something is definitely wrong, like it's too lean or too rich. The car is really sluggish and I could barely break the wheels loose when I took off at WOT. I re-installed the Diablo tune thinking that would help, but no. There are also these 2 red vacuum lines that are sucking air, and I can't for the life of me find where they plug back into!! I know it's got something to do with my HVAC controls because now when I turn the **** to vent...floor...mix...etc. nothing happens and it's stuck on defrost.
Here are the pics. Can anyone with a 96-98 GT please look at their car and see where these 2 hoses go? Thanks.
I can't help with where those lines go, but if that is your problem, (and it should be at least part of it) Plug those lines off so that you get good vacuum and try to run the car again. At least that will tell you if everything else is OK.
haha those go no where near where u have them hooked up lol. i don't know exactly what the thing they attach to is called (vacuum booster) but its right in back of your drivers side head. locate your egr valve on the intake plenum and they hook up to a black circular cylinder with two little hose hook ups comming out of it. you can't miss it. the bracket that holds this vacuum booster thing bolts on to the back of the drivers side head. the hoses route under the drivers side fuel rails. hope this helps. sry for the exact tech lingo lol but that should help you find where they go.
OK, here are some more pics to better explain.
Here you can see where the red and green hoses come out of the black cylinder looking thing, and the green hose ends on top of the EGR valve. Notice the red hose continues on.
This is where one section of the red hose goes into the TB.
And the hoses continue on...with nowhere to go!
Its been a while, but here I go....Ok well the end that DOESNT have the 90* elbow goes straight into a white plastic nipple on the other end of the vac line. Should be up near the firewall passenger side by the A/C dryer. The piece with the 90* I BELIEVE goes onto the fuel pressure regulator on the dirver side fuel rail. Its long so it can wrap around..
my bad i thought u had the drivers side screwed up. so yes the double piece does go into the plenum and the single piece does go into the fuel regulator as stated above. right to the left of the fuel regulator there plastic hose with a little nipple on it that runs down into the firewall. you should have one last hose to connect and thats where it goes. i would take some pics for ya but i smashed my camera boardin the other day.
