AC not blowing Hot
Old 01-06-2010, 02:49 PM
MeanRedStang
MeanRedStang's Avatar
Default AC not blowing Hot
Can someone help me out real quick my 98 GT isn't blowing hot air. AC works and blows fine on all speeds and cold but when switched to hot nothing happens just cold air.
MeanRedStang is offline
Old 01-06-2010, 03:16 PM
kugzgt
kugzgt's Avatar
thermostat
kugzgt is offline
Old 01-06-2010, 03:24 PM
MeanRedStang
Disregard I found it, both Coolant lines were not connected to the core but rather in a loop.
I just got the car not to long ago so I wasn't aware of it until the weather got cold.
Old 01-06-2010, 05:08 PM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
Make sure the heater core isn't leaking. That might be why it was bypassed
PROMETHEUS PRIME is offline
Old 01-06-2010, 05:49 PM
kugzgt
kugzgt's Avatar
i didnt think u would need heat down in florida anyway????
kugzgt is offline
Old 01-06-2010, 08:11 PM
cbbass123
cbbass123's Avatar
True that...most time they are bypassed because of coolant leaks or ac blend door problems.
cbbass123 is offline
Old 01-07-2010, 02:34 PM
MeanRedStang
Yeah your right I need to keep a close eye on that. I hope it isn't leaking :-( any idea where I should start looking?
Old 01-07-2010, 04:19 PM
PROMETHEUS PRIME
There is a drain in the plenum case so if it does leak it will leak coolant under the car. If that for some reason can't drain enough you will get coolant spilling on the inside by the passenger feet area
bradleyb
11-27-2015 07:50 PM
jrrhd73must
10-02-2015 09:17 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: AC not blowing Hot
