head unit problem!!
head unit problem!!
stock mach system with stock head unit and it will turn up any everything fine but when i turn the **** too fast to turn it down it will turn the volume up sometimes, is there anything i can do to fix it, my pop it off?
Thanks
Thanks
My receiver at home does that. Its just the switch itself. you can either replace the head unit or just learn to control volume slower :-p I dont know how to "take apart" the stock head unit, but if you were to get in there some how, you would probably find out the switch is dirty or something. some cleaning "could" fix it, if you "could" get it it some how.
My Mach 460 did it too, worse when the car was cold. It would try to crank all the way up sometimes. I used to just hit the Mute button then turn the volume back up to where I wanted it to be before it had started f'ing with me. Strange how they seem to magically try to crank themselves up instead of down (that may have been a little more convenient). And yeah, probably just dirt in the switch. Some electronic contact cleaner or maybe even keyboard cleaner might help if you can get it in there.
