Odometer resets everytime I start the car?
This happens for about a month or so now. When I start up the car all the needle would go all the way to the end and back to normal just as you would see when you reset the battery.
Two days ago, the car failed to start up on the first crank, but that may be due to very cold weather.
Is this a sign of dying battery? This battery is about 4-5 years old.
the needle is really reading the alt output unless the car is not running! i would get a new battery and test the alternator because bad alternator can kill a brand new battery in no time.
before changing battery check out this post <click here> and scroll down to cliffys reply , i had the same issue and this took care of it. i checked all of my fuses when i did and found a bad one though cant say for sure it was the same one but it worked.
