Finished T56 swap, problem...
Just finished the swap from my Tr3650 to a T56. Everything so far is normal except: when I let off the clutch ALL the way, I hear a metallic tapping sound that varies with engine rpm. If I apply slight pressure to the clutch pedal, it stops.
Anyone know what could cause this? I wish I understood the mechanism better
Even if you don't need to dis-assemble it again, hit up my T-56 swap thread and install The Jazzer's super-duper magnet return to save that TO bearing over time. If you do need to take it apart ... be sure to install a Ford TOB and not an aftermarket one.
Jazzer
Jazzer
Matt's 95 Stang
10-05-2015 07:16 AM
