RPM hang on 2000
RPM hang on 2000
it's fine when i normally drive it, but once i punch it and bring the RPMs to 3000 or over on WOT, it will lower from what ever RPM pretty quick, but it'll hang on 2000 for at least 10 seconds, and the longer i'm on WOT the longer it's gonna hang, once i raced my friend and did a 30-90 run, it hung for over a minute.
the mods are BBK O/R X pipe, magnaflow catback, UPR CAI, PI cams. I put a IAC restrictor plate. The car is tuned by BBR mail tune, i tried to punch the gas with both aftermarket and stock tunes, same result
if anyone ever had the same problem, let me know what the problem is.
If you know anyone w the same MAF you should try swapping to see if that helps. Your problem sounds similar to one I had and I was told that when you do a lot of induction work its not unusual to need to replace it. I cleaned mine too and it didn't help until I made the swap w a friends.
I am pegging my 90 LMAF so I need a new one this spring with a new tune.
BeatnikFink
10-01-2015 08:00 PM
