gears installed, now noise, clank
Old 01-20-2010, 05:05 PM
cisurfer
cisurfer's Avatar
Default gears installed, now noise, clank
Ive done 2 installs so far, 373s and 430s in my friends mustangs with a perfect install no noise at all...I switched out my 373s this weekend for 410s and now I have some noise...first on decel its a slight gear noise that the 430s made but went away after break in...another is a high pitched sound really faint at high speeds and the 3rd which may not be the gears in a bang/clunking sound that happens shifting and from forward to reverse...it sounds like the rear but the backlash was set at .011 and pinion preload was 25 in/lbs.....could it be U joints? the driveshaft was tightened down good but its almost like a sloppiness sound...it was a perfect install i dont see why they should make any noise at all...the only thing im worried about is the pinion depth...for some reason im not feeling right about the shim used...i used a .012 shim on the pinion and it read 1.910 is there anyone who did 4.10s who knows what the correct shim size is? it should be the same for every 8.8 id think
cisurfer is offline
Old 01-21-2010, 08:07 AM
98redstang
98redstang's Avatar
I think it could be the u joints. I have the same problem and so did my buddy with a 95 gt. He got 4.30s and he thought that was the problem but he ended up changing out the yoke and u joints and it fixed it.
98redstang is offline
Old 01-21-2010, 12:02 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
From my understanding there can be variations in the size of shims you need for the pinion gear. If I'm not mistaken, to find the size of shims you need for the new pinion is you measure the stock pinion head and the thickness of stock shims. Then you measure the new pinion head and add shims to get the same measurement from the stock pinion head and shims. The backlash you got is in the "safe zone" or whatever you will call it.
How long have you had the gears in for? Did you take multiple measurements when finding out thicknesses or backlash?
And what brand dial indicator did you use? I'm looking for a good one for myself for when I do gears in my car.
WannaBeGearHead is offline
Old 01-21-2010, 06:03 PM
Nestang
Nestang's Avatar
Heres my problem, sounds to be the same thing switching directions 1st to Reverse, If you actually watch the wish bone in the video you can see the front of the rear end torque up and down depending on direction..
http://videos.streetfire.net/video/S...lem_729688.htm
Nestang is offline
Old 01-21-2010, 06:05 PM
Nestang
Nestang's Avatar
but my rear is stock as well too, and has play but I think conrtol arm bushings are playing a big part. Plus I already got some FRPP 4.10s ready to go in.
Nestang is offline
Old 01-21-2010, 06:14 PM
Fizzics Boy
Fizzics Boy's Avatar
The gears are set up fine as I helped install them. I was saying U-joints as well since mine made a similar noise when they started going bad, though not as loud as his.
Fizzics Boy is offline
Old 01-21-2010, 11:02 PM
cisurfer
cisurfer's Avatar
well its not the u joint. put new ones in tonight and still same noise...I cant figure it out at all and its driving me nuts...if the backlash is set fine could anything else in the gears or install make this noise
cisurfer is offline
Old 01-22-2010, 02:43 AM
Nestang
Nestang's Avatar
Did you check your lower and upper control arm bushings? I think thats my main problem
Nestang is offline
Old 01-22-2010, 06:19 AM
cisurfer
cisurfer's Avatar
rep[laced lower control arms
cisurfer is offline
Granatelli Sales
01-20-2020 12:34 AM
musnicki
09-23-2015 07:11 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: gears installed, now noise, clank
