When I put on my Steeda Tri-ax I couldn't get my mach 1 shift **** to line up evenly without being too loose so I used some locktite. It's worked perfectly but, I cant seem to get it off now. I used the blue bottle if I remember correctly. Any ideas on how to get it off??
That non-slip stuff used to line toolbox drawers is good for griping things. If it's going to take a bunch of force I'd remove the handle just to make sure you don't break something in the shifter...
Next timer use Teflon pipe tape, wrap enough around the threads so that the shift **** tightens up where you want it...
