Nitrous question for 04.
OK so I jus completed my Nitrous kit on my 04gt. Basic run down is a custom wet system, 10lb bottle, Warmer, Window switch 3k rpm-5k rpm activation field, Wot switch, NOS sniper kit 75 - 125hp, Purge, NX fuel rail adaptor.
- Car has a ( 12-04-2009) 93 Diablosport predator tune
- NGK tr6 spark Plugs.
Ive tested all the parts of the system and they all funtion correctly working as they should.
Before I go test the nitrous kit what else should I check?
I had a few questions I was hopping to get answered before I do.
- I used the #24 jet for the nitrous line and a #18 jet for the fuel line . According to the book that came with the system that should be the 75hp shot nozzle setup is that correct?
- With the tune I have listed above do I need to retard timing? If so approx how much?
Anything else I should check before testing?
Thanks
Thanks
Also I was wonder if the tune I have needs to be backed off on timing bescause I think the preadators come with advanced timing over stock in those don't they? Whats your total Deg of timing?
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
