oil capacity revisited
ok so i have read that in 2002 the mustang gt was uped to use 6 quarts and the owners manual on line says 6 for the 02 and for the say 01 it says 5 quarts. I have also searched and read that the dipstick part number for the 6 quarts should be 1R3Z6750BB and the old part number is 1R3Z6750BA. Now my deleima is i have a 2002 and my owners manual says 5 and my dip stick has the ba at the end. what is goin on? Also from what i read oil pan engine block everything i sthe same from 99 to 04 is this true? If i put 6 in where will i be on my dip stick as of now i am right at the top? Help please im going nuts i just spent hours and hours looking at part numbers. Is this all because i have a car that has a build dat of 9/01. and i should add the other quart as i just did my oil change?
just changed my oil and oil filter, my dad and I always argue about this, we put 5 in, checked the level a little later, sure enough I was right and it was a quart low, 6 quarts if you change the oil filter too
Thankyou all for your replies. So i think i should be completly fine and it would be better for me to run 6 quarts instead of 5 and be alittle over on the dip stick? Is this right? I also noticed that my all data for 2002 mustang says to run 6 as well so this and the ford tecs all say 4.6 should get 6.
cliffy k i noticed that also i beleive i also have a manual that was printed in 01 for the 02 stangs cause it says o2 on cover and then under table of contents says copyrights for 2001. thankyou cliffy for all help is this right to assume? would this be what you would assume?
