crower stage 2 blower cams
im looking at getting a set of these, heres the specs:
62802-2 Stage 2
Designed specifically for supercharger applications for street use.
RPM range: 1500 to 6500+ on 4.6L, 5.4L will be lower.
262 Lobe 262
276 Valve 276
216 Lobe 216
234 Valve 234
.581 / .581
will i have to degree these cams? and what springs do you recommend if any?
62802-2 Stage 2
262 Lobe 262
276 Valve 276
216 Lobe 216
234 Valve 234
.581 / .581
Yes they should be degreed, and yes you should upgrade the valve springs. Manley, and Pacaloy make good ones from what i've heard. I assume you have and/or are doing a blower correct?
What is the LSA and intake centerline on those cams?
i may have to call crower in the morning to find the lsa and intake center on these because i cant find those specs. and yes i will be running a air to water intercooler v2 vortech. its all sitting here waiting to be installed.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
