Help: Gauge cluster issues
Old 02-09-2010, 07:57 PM
Aereon
Aereon's Avatar
Default Help: Gauge cluster issues
I just swapped my GT gauge cluster with the Mach 1 Gauge cluster. Everything works perfectly, only problem I'm having tho is the RPM gauge is not working appropriately. With the car on it shows that I'm idling at 0 RPM's. As far as the swap goes, I swapped the circuit board, started the car and saw the rpm issue, took the gauge cluster out and swapped the odometer gauge, reinstalled and have the same issue. Anyone have any insights on this?
Aereon is offline
Old 02-12-2010, 10:07 AM
IRSmart
IRSmart's Avatar
try recalbrating the needles using my how-to
IRSmart is offline
Old 02-12-2010, 10:37 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Before playing with the pointers use the HEC (Hybrid Electronic Cluster) diagnostic mode (click here for more) to read the engine speed using the tAc, tachometer, mode.
If the engine speed is properly displayed then the HEC controller is receiving and processing the tachometer signal, and something wrong with the gauge connection to the flexible PCB, the gauge motor itself, or perhaps the needle position.
If 0 is displayed then the HEC is not receiving the tachometer signal from the PCM.
cliffyk is offline
Old 02-12-2010, 04:46 PM
IRSmart
IRSmart's Avatar
good idea. i figured since he was taking the gauge cluster apart, he moved the needles inadvertantly. but it could be the sensors, i suppose.
IRSmart is offline
Old 02-12-2010, 04:57 PM
Aereon
Aereon's Avatar
i actually did a little of both to fix it, I used the diagnostic mode and corrected the needle that way.
Aereon is offline
mtgldr
02-03-2024 09:00 PM
andrew1969
16
01-08-2016 02:48 PM
SteelerNation82
09-16-2015 07:11 AM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Help: Gauge cluster issues
