clutch for 99
i'm running a Spec stage 2 and it's worked out pretty well. kinda stiff but that's just something you should expect from a clutch like that i suppose.
i'm not sure if Hays makes clutches for your car but i ran that brand in all my circle track cars and loved em.
do you have the factory t45 trans that the 99 came with or was it upgraded like example: tr3650/tko500/tko600? if you have the t45 a good clutch that i think would be great on a bolt on car is a spec stage I,II 10 1/2" clutch with a aluminum flyweel and a adjustible III peace quadrant from steeda or bbk.
We have had great success with both RAM and Exedy clutches on our Mustangs. Both have versions that will easily support the bolt ons you plan on doing
99 was originally a T-45 with a 10.5 inch clutch. I would upgrade to an 11" set up for the better surface area and holding power. An Exedy or Ram clutch kit will run between 240 and 260 for an 11 inch depending on what you choose and 250 for a billet steel flywheel.
